Decent flash for canon under 200.00?
Matt24138
Delaware
Is it possible? The reviews for most of the stuff I see are terrible.
I use LumoPro LP160's, they're well under $200 and perform beautifully, but they are all manual. You didn't mention if you needed eTTL, if so I'm not really well versed on that stuff. I learned about these flashes from Strobist, which is a great off-camera-flash resource, and they've done everything I've needed so far.
Yeah, the 160's are awsome, I use them primarily and put them through a lot. No problems yet. If you need eTTL, you can get a used 430EXII for around $250 and they're capable from what I've seen.
It doesn't seem to have an optical trigger, pc-sync/1/8th" port, zoom, and only has 4 "stops". Does it have Manual mode at all? The product description is pretty lacking... it's hard to tell what it does. Could you give the details?
The LP160 has 1/1 through 1/64 power, slave optical and intelligent slave (ignores first flash for TTL, although I've never used this), full pan and tilt head, pc-sync, 1/8th" port, large zoom range, auto-power saver, 140 guide #, comes with a plastic foot for sitting on the ground, and a wide angle attachment which is also handy for holding gels and diffusion. And it's tough as nails, I've dropped one of mine from about 6 feet up onto hard thin carpet and it keeps on tickin'.
Don't skimp on your flash. Get a good one and you can use it for life.
There's always the Yongnuo option, which is probably the cheapest, but it has a sketchy success/failure ratio. Might want to also look into Nissin and Sigma. Older models, like the Canon 550EX, 420EX, 430EX (I) may be worth looking into as well.
