- Joined
- Jun 7, 2012
- Messages
- 15,504
- Reaction score
- 7,901
- Location
- Central Florida
- Can others edit my Photos
- Photos NOT OK to edit
- Moderator 🛠️
- #1
This came to me via an acquaintance who decided to go back to photographing people in daylight at a park. this set was used once. yes...once.
its a pretty basic continuous light setup, typical of many other cheap brands of equipment like promaster or cowboy studio. Only two settings, ON and OFF. (these things are bright) comes with two pretty decent stands, two light heads, one 36" shoot through umbrella, one 36" silver reflective umbrella, and 3 light bulbs. everything is tested and working. (does not come with any backgrounds or backdrop stands)
we don't use continuous lighting, and prefer lighting we have more control over, but if you just want to get light on a subject, these will do the job. I really have little to no experience with these sort of lights, so if the answer is not in one of the pictures, I probably wont be of much help.
now...on to the technical stuffs.
we are Donating this setup to a good home.
(due to the cost of shipping this, the donation range will be limited to continental U.S. only.)
(package is 40x11x14 @ 18lbs for reference)
We will cover the shipping cost.
Out of pocket expense to the recipient of this donation will be $0 (zero) dollars.
to be eligible for this donation you must meet the following criteria.
-be a reasonably active member of the forum
-actually need portrait lighting. (if you have flashes or strobes, you don't need/want these.)
-actually want to shoot with portrait lighting. (if you only want/plan to shoot natural light portraits, you don't need these)
-not care too much that they are a cheap set of lights.
Failure to follow donation protocol may (and probably will) exclude you from consideration.
If you feel you meet the criteria and want to be considered for this, post a few of your portrait shots in this thread along with a brief explanation of how you feel lights would help improve your photography and/or tanning.
disclaimer:
me and the wife reserve the right to alter and/or cancel this donation at any given time for any dumb old reason.
disclaimer:
