Dropped Nikon D700 Camea - Lens saved by a UV filter
gkinney
Carrollton, Tx
This is why I always keep a Clear Class filter (Or UV) on my lenses.
I did not zip my backpack, and when I threw it up on my shoulder, my Nikon D700 and $1200.00 24-120 lens hit the floor.... (See picture below)
I suggest that anyone that is starting out with a decent DSLR make sure and get clear glass filters for all your lenses... It saved mine!
You might want to see this video before you think its all about filter protection
most of the time the filter cracks when a lens won't because the filter is ultra thin glass. The result then is that glass shards from the filter can kick back and scratch all over the front element - furthermore filters often get stick or cripple the filter thread if a lens is dropped - adding to removal problems.
Against dust, light dirt, salt water, mud, sticky fingers etc... a filter is a useful protection. Against harder impacts its more of a risk
STATE FARM INSURANCE <---protects all the lenses in my sig, no crappy filters attached =)
Agree with Overread. Chances are, your filter and the shards of glass caused more damage to your front element than the drop would have. Horrible idea, IMO, and a really bad example of why to use filters. A lens hood would have provided a lot more protection.
why did you throw your camera in your pack without a lens cap on it? No matter how soft the inner lining of your pack is, you'll get scratches on the filter, and if your filter is always on your lens, then your lens might as well be scratched.
Best protection: hood and/or lens cap.
^^^that
Normally my lens cap is on, and my hood is always on when I'm shooting. I was up late cleaning my gear and obviously forgot to put on the cap. I was in a hurry that morning (That's why my backpack was not closed all the way) and that was the biggest mistake of all.
I had the lens inspected and it checked out ok.
Filters may not be the best protection as has been pointed out. But for ME this works as a stop gap as a second layer to forgetfulness.
Just sharing my experiences.
also, if you'll notice, the crack came from it hitting the outside of the rim of the filter (see where it's bent in the top left), not a direct drop on the glass, and the thin glass then buckling. I'd be willing to bet that your lens would have been completely unhurt without the filter. I think people see a shattered filter in cases like these and assume their lens would have been toast. Probably not the case in a situation like this.
The only time a filter really protects is if a relatively sharp object directly impacts the glass of the filter.
I often shoot paintball, and the filter saved me once before. I wouldn't like to test a lens against a paintball shot from 20 feet away going close to 300 fps :p
Watch Overread's video above
paintball would be a situation where a filter could help, but more because of the paint than the impact.
I'm not a protective filter guy either, but hey, at the end of the day, you're out a filter and not a new lens. I'd say that's a good thing!
I used to believe the filter was a protection device too, and had one on every lens I own. I even have one of these stories:
As you can clearly see, that's my 100-400mm f/4.5-5.6 L IS, in a shot taken just after flying off the front seat at a high rate of speed when I had to lock up the brakes one day. I had a heck of a time getting that filter off afterwards. I ended up taking it to a mechanic and asking if he had a big rubber oil filter wrench that I could try on it. With him holding tightly to the lens, and me cranking on the wrench, we finally got it off. He said he was sure with all the effort we put into it that we would damage the lens in the process but, thankfully, it survived. I promptly bought another filter and put it on to get "protected" again.
Then one day more than a year later, I was cleaning my sensor. To inspect the job I'd done, I put on a lens, stopped it down as far as it would go, pointed it at a white wall, and took a shot. Then I loaded the shot up in Lightroom to pixel peep it, looking for any remaining dust spots. I'd done a good job and none remained, but something else bothered me: faint rainbow colored rings. I looked at the white wall. I looked at the rainbow rings. Huh? I looked at the lens. I looked again at the rainbow rings. Huh?
Then I thought I should just try it without the filter, just to see what happens. I honestly didn't expect removing the filter to change anything, but I was trying to figure it out, and I wanted to be thorough. Filter off, I took another shot and examined it. No rainbows, just white. Hmmm... Filter back on, take another shot, rainbows are back. And these were expensive filters too. I justified the expense of better quality filters with the idea that I didn't want to put a cheap window in front of my expensive glass.
That was the end of my filter use for "protection". The only filters that go on one of my lenses any more are for a specific task, and that's either a polarizer or a neutral density filter.
YMMV
Actually, that's not likely.
You do not know that the filter saved your lens, you can only speculate. All you know for sure is that you have a shattered filter. Overread and the others sum up nicely.
Overread should 'sticky' this thread.
If you look at the 'Construction Image' of the AF-S NIKKOR 24-120mm f/4G ED VR from Nikon you'll see that the front lens element itself is much thicker than the filter, quite thick around the edge where it is supported, and is backed by even more glass, and ED lens element and another aberration correcting lens..
You probably should have the lens mount (camera and lens) checked to be sure they didn't get bent out of shape and ask that they check the calibration of the focus and metering systems too.
