illumiNation
- Joined
- May 5, 2012
- Messages
- 26
- Reaction score
- 2
Agreed, though I think the concept alone is good enough to warrant a re-shoot, rather than trying to post process it.It's a nice shot, but the flare in the centre really kills it. I think with some work on the processing side, you'd have a really nice image here.
Possibly. Depends on the source of the flare.Would use of a polarizing filter cut down the flare or a lens hood?
Here's a soft rubber one that's very inexpensive, and should work fine: Amazon.com: Zeikos ZE-LH52 52mm Soft Rubber Lens Hood (Black): Camera & PhotoThanks guys what lens good would you recommend for a canon 50mm 1.8, or are they all about the same?
Agree! If you don't need a petal-shaped hood (usually for wider-angles) then the circular, round, rubber ones are excellent.Here's a soft rubber one that's very inexpensive, and should work fine: Amazon.com: Zeikos ZE-LH52 52mm Soft Rubber Lens Hood (Black): Camera & PhotoThanks guys what lens good would you recommend for a canon 50mm 1.8, or are they all about the same?
There are some folks out there saying that the hard plastic ones contributed to damage on the 50mm 1.8 because the build of that lens is not up to the task of dealing with the hard plastic bumping into something without causing the front element to come loose. I use rubber hoods on some of my lenses, and they do the job just fine, so on this one, I'd say, "better safe than sorry".
