Fine art photo critique ?
I don't know what other category that kind of photographs could be.
These are "still life".
Right, didn't think of that either ! Thanks !
So those are part of my early shots. I think (to answer to the why questions, Lew) in retrospect that I was just looking to create a picture whose colors matched and were pleasing to the eye, I was going for the feel of it. Which might explain the closeness to the unexeptionnal coffee machine dial. It was just that this was the only framing possible (or what I thought was the best one) to get those colors, that set of tones, but indeed not particular meaning of both the coffee and the coffee machine other than they looked good and contributed to the feel I was looking for. For the photo of the buckle and book, I was going for that vintage/retro/worn feel.
As for the jam/spoon picture, I just couldn't frame higher and include the spoon and shadow because that was the edge of the plate, and the surface underneath it wasn't that great. But OK, I get the point. I thought the movement in the 'placement' of the jam was a foreground subject of enough interest though ? Oh but right, it is oof, so that kinda undermines my argument of it being a good subject of attention (am I not mistaken here ?).
For the buckle thing, I am aware that indeed the ' 'Such a perfect book' Nick Hornby' is being made the center of interest because it is in the buckle though it's not, I indeed didn't want to show specifically that. I wish that thing wasn't on the cover of the book but it was. But the title of the book is in the buckle, and that's what I was going for, and leaving the name of the author outside it (I'm aware that it is a bit hidden by the thickness of the buckle, that's not good I agree).
Timor,
Shallow DoF is very good in bringing up the the subject "forward", but starts to be a problem if cuts of parts of the story and sens of the picture (#4 and 6)
Yes I do agree for those two pictures indeed. Would you have said the same thing if the blur was lessened ? Because, as I mentionned, these are my early pictures, I don't have a very good control of the amount of blur I put on OOF zones through aperture and focal length manipulation.
In any case placement of sharp zone of the picture in essentially soft picture undergoes the same "rules" of composition like everything else in order to produce pleasant picture (#6)
For that picture, you're referring to the rules of composition, but the focused herbs heap is at the intersection of the lines of the rule of third, isn't it ? A bit off to the left, but still on the horizontal bottom line ? Plus the alignment of the heaps (I'm not sure that's the right term sorry) diagonally through the frame creates some sort of order, doesn't it ?
As in #3 it is a small problem, in #2 it is mighty distracting
Ok, I understand that. About #2 (buckle and book), what if the title of the book was clearly in the center of the buckle and if there wasn't that other text lines (' 'such a perfect book'...') under it ? Would that have clearly shown that the title of the book was what I would have meant to put forward ?
#5 is too flat and as a result... too flat. Maybe in colour version would look more interesting ?
I agree that the whole front part of the guitar is some kind of flat grey, but what about the pick ? It is sharp, has a good contrast and the name of the guitar brand printed on it, so wouldn't the flatness of the whole picture draw attention to the sole pick ?
The strings running diagonally across the photo also create some sort of pattern to me, am I wrong to think it is a (relatively) good element of the composition ?
As for the tea thing (it actually is a filter, hanged upside down by a photoshopped out piece of string) :
Concerning the "drown in shadows" : I kinda liked the fact that it was 'surrounded by nothing', the big amount of black 'pushing' (I felt) the attention to the reflection of the flash onto the inscriptions/sculpted patterns on the metal on the side of the object, and in your crop Timor I don't feel that.
I tried to put more space at the bottom and right (for the original picture, or bottom and left for the mirrored picture), but then the whole scene ended up being in the dead center of the frame, I didn't like that. I thought that the bottom of the light cercle on the woodfloor could be legitimately out of the frame as it is not the actual subject, a bit like the bottom of the neck in a portrait of a person.
In any case thank you very much for your comments, I really found them constructive and they made me look back and analyze what I did, and, most importantly maybe, why.
Lucas
Lucas, you've received for detailed critique from very critical eyes. In general the shots are fantastic for someone new to photography (much better than me!)
Overall I like the ideas and the shots very much.
Sent from my iPhone using Tapatalk
I have to say, that you took our opinions quite well. The truth is, that photography is a very flexible art, many things go. Yet, when comes to composition, one thing is superior: harmony. And harmony is not only placing the subject in one of the strong points of the frame, that also interaction with the other elements of the picture which is sometimes called a balance or correlation of internal and external events (A. Adams) as photography is "copping" facts of physical world. But then you can have your own approach. The test point is, if people like to watch your pictures. Make a test yourself, print something (just well) you consider good and pin it to your wall. This is the best way to study own actions. Let see, if after two months your opinion about that picture will be still the same.
Ok so I should put things into perspective. Thanks benp2k6 !
Absolutely not. Rather go to your nearest library and see some books about painting. Not photography. Study for a bit great French painters. Never rest, always look out. Train your eyes to see, what others don't. Visualize. Carry with you small p&s everywhere.
