First time DSLR buyer looking for advice on purchase
wristybusiness
Hi all,
I am looking to buy a decent quality DSLR for a trip abroad for a price that won't hurt me too much if its stolen or damaged.
I found a Sony Alpha A200, including 18-55mm SAM lens, 'new battery', Tiffen polarized filter, 8GB high speed memory card, matching bag, charger and all cables.
I have found out there is about 2000 shutter actuations. He tells me the camera and lens are in great shape.
I have negotiated him down to $220.
What do you think of this price? Is there
[FONT=Arial, Verdana, Helvetica, sans-serif]something else I should ask about the camera? What about when I take a look at it? I have never purchased one used and would appreciate your input!
Thanks!
[/FONT]
For that price, it is a pretty decent deal. The A200 is not the nicest of Sony's cameras (it is only 10.2 megapixels, the sensor is a CCD, not a CMOS, and, because it still uses the pentaprism instead of the newer translucent, it only shoots 3 fps), but the price for this one is lower than many point and shoots, so I would say go for it. It USED to be $700 back in 2008...
The 18-55 is the new kit lens, which is A LOT better than the 18-70mm that the A200 came with. Mind you, it is STILL a kit lens, so it's not like it is top of the line or anything, but it is really not a bad lens at all. And if you DO decide to get a better body, the lenses of this one will fit, so you already are a steap ahead if you buy other lenses... Now, that kit lens is only equivalent to a 3X zoom, so you MAY want to get another lens if you plan on long range shots. The 55-200mm one (SAL55200) is pretty good. If you want more zoom power at an affordable price, there is a 75-300mm, but that one does suffer from distortion and chromatic aberration (SAL75300). If you are willing to sacrifice a bit of quality for more zoom, that may be an option (for me, though, I would rather have the 55-200mm). The A200 already had the Super Steady Shot inside the body, so all lenses will benefit from image stabilization...
Thank you for you great advice!
I made the purchase and will likely get a lens for long range shots :)
i started with one of those. Its okay. Get a minolta 70-210 f4 good solid lens and cheap. Get a minolta 50mm f1.7 too. You could probably get both for less then $200 total.
