Bush
- Joined
- Mar 18, 2013
- Messages
- 13
- Reaction score
- 4
- Location
- Orlando
- Can others edit my Photos
- Photos NOT OK to edit
I'm going to start this off by saying, this is a very basic lesson, more so for someone just getting into using flash and doesn't understand or know what they are doing. going off of the response of this post i may post a more advanced lesson on flash. but for now we are going to the basics. Along with it being very basic i am going to be also going off of a general speedlight flash setting. I don't know what gear you have so i can't make this 100% specific for you.
Flash took me a long time to figure out and learn how to properly use, in here i want to get you started off right, by knowing the techniques, some do's and don'ts and some essential accessories.
First we will start with your flash set up.
you have multiple setting on your flash :
A - Auto - it automatically sets your flash up for what it thinks you need by how your camera is set.
M - Manual - you set your flash up
RPT - Repeat - your flash will go off 1-2-3 or 4 times while your shutter is open. (This is dependent on your flash type camera, and how many times you set it for.)
TTL - Through The Lens - this one is a little like auto, but instead of going off of your camera settings this one goes off of the subject you are focusing on. (this is a more preferd setting for a lot of photographers and a good one to start with.)
Along with all of these there is a separate setting that i have found surprising that a lot of photographers do not know about or know what it is. and that is: EV - Exposure Value- This makes it to where if you are using TTL but it is over exposing your subject a little bit but the background is perfect, you can drop the EV -3 and get the exposure you are looking for.
Now we will talk about flash techniques.
Bounce Flash - ​This is bouncing your flash off of your surroundings or a card to light the subject with a natural look. Doing this defuses the light making it a softer light, reducing the chance of hot spots and red eye. Along with this, know your surroundings. what you bounce your flash off of could discolor or give a weird shadow or lighting across your subject.
Fill Light -This is using flash to properly light a subject that might be shadowed. This is good to use if someone is wearing a ball cap and has a shadow over there eyes or standing next to blinds and has harsh shadows across them.
Synchro Sun - This is a lot like fill flash, but with this you are going to expose for the bright background, and then flash the subject so that your background is not blasted and your subject is well lit and not a silhouette. This is good to use on a sunny day or if you are at a concert and the stage lights are blasting your photo. http://media.digitalcameraworld.com...hotography_fill_flash_NIK07.zone_2.finish.jpg sorry not the best example on this one.
Direct Flash - I am going to cover this so you know. This is having your flash pointed straight at your subject. This is a big NO! The only time I use this is for crime scenes and mugshots. And that is because there are guidelines for crimes and mugs that you have to go by.
Off Camera Flash -This is obviously having your flash off camera either remote or by cord. This way can look like bounce flash if defused, or it can be a harsh light or anything between. This is used for when you can't bounce your flash, or if you are taking a dramatic photo, and so on. Example: http://image11.photobiz.com/3575/36_20120612094200_77846_medium.jpg
All of these except for direct flash can be very fun to use and once you learn how, you can make some very creative photography with them.
Since off camera flash was mentioned, and if you do not have a cord to sync your flash, remote is your way. most cameras work as a remote now a-days, so you will have to read your manual and figure out how to set your camera as a remote. and then being as flashes vary you will have to do the same on how to set your flash up as a receiver.
Now a slightly more advanced technique.
Rear Curtain Sync -This is a setting on your camera, not your flash. Your camera is automatically set to Front curtain sync, which works like so [Shutter opens, Flash goes off -- Shutter closes] The second your Shutter opens your flash pops. Rear curtain Sync is the exact opposite, your Shutter opens, and then just before it closes, the flash goes off. This is used a lot for blur to stop motion. Example : http://digital-photography-school.com/wp-content/uploads/2007/01/slow-sync-flash-2.jpg
Last but not least, you need defusers. Different types and colors, and bounce cards.
Well I hope this helps out some of the new to flash photographers.
