dukeboy1977
- Joined
- Apr 19, 2009
- Messages
- 221
- Reaction score
- 0
- Location
- erie, PA
- Can others edit my Photos
- Photos OK to edit
i think your right about the shaking, i do have a tri-pod, the shutter speed was at half a second, the only problem is how hard it is to get the tri-pod to hold hte camera the way i was holding it, ill try it though, thanks again for all the help.heres f/16 manual focused as best as i could
You focusing looks a little off...what is your shutter speed used? Maybe it's camera shake causing it to be blurry? Try using a tripod if you have 1, or use pillows in your lap to help you steady your camera by putting your elbows into them firmly when holding your camera. I dunno what the problem is, but its better...just not great. Keep trying
Try setting your shutter speed higher. What lens are you using? Make your speed 1/? your focal length is or one step higher. That might help your camera shake.
