musicaleCA
- Joined
- May 23, 2009
- Messages
- 2,303
- Reaction score
- 0
- Location
- Vancouver, BC
- Can others edit my Photos
- Photos OK to edit
The sensor only records the light that is passing THROUGH THE LENS.No, it pertains to sensors. I said all things being equal. Take an EF 50mm and slap it on a full-frame as opposed to a crop, and you're going to get more vignetting and softness on the corners than the crop, because the crop is only taking the image from the centre sweet spot of the lens.
I don't know Canon nomenclature for their lenses. Is an EF lens designed for a cropped sensor, much like Nikkor's DX lens? If so, then all things aren't equal. Mounting a lens designed for a cropped sensor on a full frame may likely cause issues as you described because that is not how the lens was engineered to be used. But vignetting, softness at borders and DoF is a product of the lens, not the sensor.
EF lenses are designed for full-frames. EF-S lenses are designed for Canon's crop frames. I know that vignetting and softness at the corners are products of the lens, but my point is that if you use a lens for a full-frame body on a crop body, you're only getting the sweet spot and thus won't get as much of those abberations as the same lens on a full-frame. If it's and EF-S lens, designed for a crop body on a crop body, then the abberations are still there.
Boy, am I ever having trouble communicating effectively in this thread.
There are a few practical benefits of to consider when looking at lenses designed for crop bodies. They're almost always smaller and lighter than their full-frame equivalent; they simply need less glass to get the same FoV. As an example, my EF-S 55-250mm is effectively the equivalent of an 88-400(!)mm on a full-frame body. And it is very, very light compared to its EF, full-frame equivalents. For some, this can be an important consideration. (If you're running around covering an event and have two cameras around your neck, one telephoto, one wide, do you really want the telephoto to be the size and weight of a baby?
