You'll only have that issue if you shoot in DX mode.
FX bodies are shipped from the factory to default to DX mode when the camera detects a DX-format lens on it. When it is DX mode, you will see a small double-sided rectangle with 'DX' in it on the monitor and a black rectangle in the viewfinder.
You can over-ride this in the menus and shoot with it in FX mode.
BTW, the 35 DX lens does very well covering the FX sensor, so don't be afraid to shoot it in FX mode. It is a rarity as most DX lenses simply do not cover the FX sensor and you will have a black vignette in the corners of the image.
This thread begs for the all to familiar reply to such situations, Have You Read The Freaking Manual???
While I appreciate that Nikon does not hire the best writers, and I am a lowly Canon user used to pretty decent manuals. Page 285 thru 291 are I believe pretty well written. I, a Canon understood it. I even learned about CPU, Type G/E and Type D lenses and the pretty illustration on page 291 along with the instructions were pretty good.
Mostly due to the fact that you were probably more than well-versed in knowing what they were talking about in the first place.
thank you to everyone that actually answered my question about this, I'm not good with all these technical terms and names and numbers and stuff I finally watched a vidoe that totally helped to understand the problem and the issue that I was having, along with a user guide video. I guess I'm just gonna have to get an actual fx to see what the difference is.
I misunderstood.
But you don't have a FX lens at all to compare.
Yes you are getting a "cropped" image which is using only a central part of your sensor. And giving you a DX look.
You can pick up a 35mm/2.8 AF-D lens for not much money and get a direct comparison.
This viewfinder shot is from a nikon d600. The middle rectangle is the DX Cropped image in relation to the entire frame which is FX
from this thread talking about DX/FX but the images have been archived ==>
So You Wanna See the Difference Between Full Frame and Cropped Sensors?[/QUOTE
Thank you that was very helpful, I was able to figure out how to use my dx lens and disable the cropping except now I'm getting some vignetting and while it's not that bothersome I fee like I'm not getting a true image until I fiddle with the settings a lot and eventually get it right , I like doing it all munally but I'm getting the hang of it. No at the moment I don't have an actual fx lens to compare it to buy my concer was once I get an actual fx lens will i get an actually bigger image with the same capabilities as I had on the dx camera?
