Help An Old Person Learn New PS Tricks
The Beautiful Hills of East Tennessee
I've used PS for many years, since even before it had CS attached to its version number.
But I'll admit--I've been mired in "Intermediate" (actually, that's probably overstating my skills--really skilled Beginner, perhaps) for many, many years. I knew how to do a few things really well, and that was fine, because a few things were all I had need of.
But the past few years, as my photography has progressed, I find myself needing a lot better skills. And I've been learning, a lot. Heck, I hadn't even worked with layers or masking until about a year ago! Sad, but true!!
Anyway…one of my goals this year is to really up my PS skills. Maybe not to Advanced, but at least a more solid Intermediate.
My current "project" is playing with smoke photography--I'm also doing it to try to give my creative juices a post-winter boost, but it also has the advantage of requiring me to venture into some new territory with PS. I've done smoke photography before, but just the basic stuff--post processing was just adjusting some settings in ACR, maybe inverting and adding a gradient, that sort of thing.
Now, I want to take ONE smoke photo image, use several copies of that same image, layered and then rotated--a composite, that's what I want. But using copies of the same single image.
But I'm struggling. It's not working the way I thought it would.
Here's what I've done so far (other than the basic processing):
1. Cropped my image to the portion I wanted to use and duplicate. The result was a 8" square image.
2. Resized my canvas to a 16" square, to allow adequate room to add multiple copies of the image layered on top of each other.
3. Selected the image and duplicate that layer. Okay, now I have TWO identical layers.
4. Selected the top layer (the new "copy") and rotated it.
That's as far as I've gotten, and I have two major problems I'm getting frustrated by.
1. The top layer covers the bottom layer completely. I can see one or the other, but not both--am I going to have to mask every copy or something? That would be a major buttload of work, wouldn't it?
2. When I rotated that top layer--the bottom layer rotates too! I want to rotate JUST that one layer, so that the smoke in that image is pointed a different direction than in the original image. I'm assuming that this is because I used "duplicate layer" and I should do this a different way?
If anyone even knows what I'm talking about and wants to chime in, with either some help themselves, or a good tutorial, I'd appreciate it. I've searched and searched for a tut on doing what I want, but I'm evidently not savvy enough to know the right keywords to get me the results I need for this.
You just need a good dose of "Blending Modes". (drop-down that normally displays "Normal" on the Layers Palette)
So, you have two layers, one atop the other. On the top layer, if you want the black/dark stuff to be invisible and show what's underneath, change the blending mode to "Screen" or one of the others in that "Lighten" group. If you want the opposite, to have the whites/lights be basically invisible and show what's under that layer, change the blending mode to "Multiply" or one of the others in the "Darken" group.
Play with those, and you'll see how easy this can get. :)
ETA: OH, and on the rotating, choose the layer you want to rotate, hit CTRL or Command "T", then grab the handles that pop up around that layer, and rotate it to your heart's content.
One more thing: This will come in REALLY handy for repeating EXACTLY how far you rotate over and over as many times as you like to achieve symmetry:
Create and Replace a Custom Background in Photoshop
In fact, you should get friendly with that whole web site if you want to up your Photoshop game. The free stuff is great, but the paid tutorials are crazy great.
  • Thread Starter 🔹
  • Moderator 🛠️
  • #3
Thanks, Buckster! I tried a couple of blending modes, but the wrong ones evidently, so I gave up on that idea. I used Overlay and then I tried, I think, Luminosity. Neither worked so I thought I must not be on the right track with that.
I'll give your instructions a go as soon as I can on that and the rotation issue.
I LOVE phlearn!! Just discovered it a few months ago, and so far have only done the freebies. If the paid ones are better, I'm in!
  • Thread Starter 🔹
  • Moderator 🛠️
  • #4
Okay, well thanks to @Buckster, I think I ended up with a pretty decent first attempt. Definitely still have some issues to deal with, but not a bad first go! Thanks, Buck!
Ohh! I ABSOLUTELY LOVE THIS! The colors are spectacular!
And the name for that will be... Singularity.
  • Thread Starter 🔹
  • Moderator 🛠️
  • #10
Thanks, all! Once Buckster helped me get over the initial hurdles, it went pretty well and I found it incredibly addictive. The particular smoke photo I chose, I didn't even have very high hopes for, just figured it didn't matter; anything would do until I figured out what I was doing. So I was really quite pleased with how it turned out.
I like that!!
  • Thread Starter 🔹
  • Moderator 🛠️
  • #11
Just for fun, here's the same image after some further manipulations: mostly just duplicating, rotating and changing blending modes.
I just noticed some cleanup work that could be done to the edges, if I were so inclined. But I'm probably not.
I just thought it was interesting how different the two images are.
  • Thread Starter 🔹
  • Moderator 🛠️
  • #13
Hmm... I think maybe too much of a good thing Sharon...
Oh, I should have said that. This is entirely just for fun. I GREATLY prefer the first picture; this one is way too busy and blaring for me. I just thought it was interesting how drastically different you can make something look with a few turns and blending mode changes.
The new Spirograph... I'm pretty sure that PS has somewhere in its universe a set of "actions" that give you that capability. But I really do like the abstracts that can be created with this. Might have to give it a whirl.
