thanks a lot.
Image about 1000 pixels would have been fine but these are a great size.
Of the second set.
#1
interesting composition, particularly in light of the idea that the couple is engaged. The vertical and horizontal lines of the window are very close to square and could be transformed to make them perfect if desired. The conversion is very handsome although his jacket would provide more interest and wouldn't be a black hole, if it wasn't quite so dark. The columns are vital to get the subjects off the margin and, unfortunately, the column on the right is totally burnt out and will always be a distracting bright bar that would distract on any print.
2. very nice, nice composition, good use of DOF, nice intimate pose. I would vignette the corners slightly to keep the viewer eye's on the couple. Printed on a grainy or watercolor paper will be a great shot for any album.
3. This will be a real memory shot to treasure. Recognizable profiles, limned by the sunset, closely interacting. Yes, one sees lots of shots like this but this one is a success - helped by the attractive profiles. I would consider cropping it to 4 x 5 removing ~equal amounts top and bottom and make the composition tighter. You don't need that extra half inch each end.
4. Eliminate this. It is dramatically OOF, underexposed with lots of ugly flare and says nothing but 'mistake.'
