You want a camera with a larger sensor and preferably a long lens -- especially with low focal ratio. Laws of physics come into play here.The three things that contribute to this are: (1) larger physical sensor sizes. (2) lower focal ratio (f-stop), and (3) longer focal lengths.If you really want this, think about getting a large camera -- such as an entry level DSLR -- as your next camera.
Contrary to popular belief, longer focal lengths doesn't really add much to Bokeh at the same magnification.
Now you're changing the issue. Longer lenses dont have the same magnification unless you crop. Technically the DoF does not get narrower and the bokeh doesn't get stronger because the lens is "longer". Really it's the true angle of view becoming narrower that does this. That means you can crop in on a short lense to make it seem like a long lens and the magnified view magnifies everything... including blur. If you do this, you're also simulating a smaller sensor -- so the issue is a little more complex. But the simple answer is that if you shoot with a longer lens at the same low focal ratio then a short lens, and you don't crop either, then the shot with the longer lens will have a narrower DoF and more intensified bokeh.
