Yes to the above recommendation about a power adapter. (I have one and it works fine.)
In addition, you'll want to consider how you're building the time lapse. There are two main approaches.
First, you can shoot in video mode by altering the frame rate. I assume that you would NOT want this option for now. But it's something to think about in the future. This is possible (and works well) by using the Magic Lantern software. This has the advantage of not exercising the shutter hundreds (to thousands) to times. But also has the disadvantage of being power-hungry. (And you would definitely need the A/C power adapter.)
Second, you can shoot individual frames and render them into a movie later. I think you'll want to do this. This is a common approach with many options. I think(!) that you'll want this variation for something like an orchid. In addition, you may not be wanting or needing to shoot at the same frame rate for all hours. For example, you may want to capture more frame during daytime hours and fewer during nighttime hours. (I don't know enough about botany to recommend.)
Regardless, you'll need some kind of intervalometer. I have this one:
Amazon.com : Neewer LCD Timer Shutter Release Remote Control for Canon 700D/T5i, 650D/T4i, 550D/T2i, 500D/T1i, 350D/XT, 400D/XTi, 1000D/XS, 450D/XSi, 60D, 100D, and Pentax : Telescope Remote Controls : Camera & Photo
It's cheap and works fine. You'd be able to alter the frame rate on the remote control without touching the camera.
When the frame rate is low (like 1 frame every few minutes), you can turn off things like auto-focus and the back monitor display to save power. Also, set the camera to go to sleep fairly quickly (after 30 seconds - on the yellow wrench menu, first option). The intervalometer will wake the camera up, take the picture and it will go back to sleep. I've done this on a T3i and taken over 1000 pictures on a battery.
