It almost looks like it is reading the papers in the first shot. :mrgreen:
Do you breed these spiders?![]()
Did you use the SB600 to light? Did you use TTL? Did you use max sync speed? The lighting seems a bit hot, especially in #1. With the SB600 you can use a bounce card and tilt the flash so the it's not a direct hit if you don't have any other diffusion.
Interesting looking spider.
Okay, if you say so. But there are a few spots on the cephalothorax (particularly on #2 below the eye) and the abdomen on both that DO have blown whites on my monitor. As confirmation, look at the legs. Although I can't identify this spider, I also find it hard to believe that the white strips on the legs are part of the anatomy rather than flash reflection.
BTW, I am on a calibrated monitor. Not trying to be confrontational, just observant.
I'm glad you added the second paragraph, otherwise.........
Harsh lighting is subjective, but in macro land it's a pretty easy slice of the pie.
What were your settings, camera and flash. Where was you flash with respect to lens axis and distance to subject? You stated you were 12" below, but the shots look eye level.
Nate the shots look great. Im no expert on lighting but I usually have the same issue and I think on my part its mostly because the the flash is hitting the subject head on. Im working on getting 2 flashes and a bracket to try and hit the subject at 45 degrees (with both flashes one on each side)to the lens. I also use a lumiquest softbox and it still has that effect sometimes.
