I gave it my best shot..
TamiAz
Arizona
Here's a picture I took today using my speedlight and umbrella. I didn't bother editing the plant out since I won't be giving it to my friend.. What do you think? How bad? Thanks.
She has pin lights in her eyes..How do you avoid that?
Moved to the People Photography Gallery per new guidelines for the Beginner's Forum.
Read the new Beginners Forum description when you get a chance.
Don't use an apparently small light source. If you are using your pop-up flash to trigger the off camera speedlight you can use something like a Nikon SG-3IR IR Panel to block the visible light from the pop-up but let the IR light through so the speedlight triggers.
I used my wireless remote. Will I always get pin lights when using a shoot through umbrella? Thanks for the link..I didn't know they made something like that.
No. I never get pin lights with the shoot through. Maybe bringing it closer would help...
You need to look at your picture closely and try to ask yourself what could make it better.
Note:
how bright (and pale looking) her skin is
how bright the background is - close to her color
how bright the dress is - enough to pull the eye
If you change all of those and crop to remove space that doesn't do anything, the picture looks more lush and her color look better, I think.
Two minor nitpicks from me. First is that shooting down at the subject diminishes and subordinates them. Shooting from the subject's eye level makes it look more appropriate in my opinion. Second is that her smile looks forced and not natural.
I do think you did an excellent job with the exposure though, better than I could have done. I think Lew's edit looks better because it emphasizes the subject and not the background but it requires a good exposure to start with.
The pin lights can easily be cloned out.
Note:
I like how you edited the picture..Would you mind sharing how you did it? I'm just learning how to edit pictures. Thank you!!
Get down on her level... much more attractive that way! It would have been a killer shot if you had done that! :)
Note:
What software do you use to edit?
Lew
Note:
Lew
I have Photoshop elements and Lightroom.
You've got nice soft light going here, even if it is a little flat.
If you move the light more to the side, you'll pick up more shadow gradient. Try pulling her further away from the background and get the light closer to her.
Remember... when you want soft light
the larger the light source (in relation to the subject), the softer the light.
The closer the light source is to the subject, the softer the light (as apparent light source is larger). Always try to get the modifier as close as possible to the subject... better catchlights, and softer light..
