...a lot of your assumptions were off unfortunately...such as the flash..I didnt use one at all.
A lot? What else aside from the flash was I "off" about?
You didn't bother to tell me what you *were* using for lighting, if anything, and where your lights may have been placed?
So replace the word "On camera flash" with, "on axis light".
Doesn't matter if you were using a flash or:
a construction lamp with a white t-shirt over the front.
My point was that, if I recall correctly, the shot with the head cut off, for example, had a shadow which indicated that you had a light coming from close to directly in front of the model.
It wasn't flattering.
You may have had it "raised" a bit, but all the same the lighting wasn't flattering.
I can appreciate that you're just starting out... we all start somewhere, however, seeing as you *are* just starting out, I'm curious as to what else I was "off" about, considering all of my comments were on the flaws of the technical aspects of your images... "a lot" apparently.
And I can assure you now that when I stated you were using a wide-angle... I wasn't "off" about that. I *know* I'm right about that because I checked your EXIF data... so unless you're camera data is lying... and I'm guessing it's not... that was something I was able to read off of your image.
We take the time to comment for the same reason you post. You want to improve... we want to *help* you improve. I can appreciate a busy lifestyle, but if you're going to post on a forum and people take the time to give you feedback, it doesn't take that much time to, at the very least say, "Thanks for your feedback. I'm going to try again, like you stated", otherwise it just *looks* like a defensive move to delete and run without a word.
Anyway, keep practicing and posting (and interacting :greenpbl: ). It takes time, but you'll get it eventually.
