Is it just me (or the cathedral) but doesn't it need to be standing up straight?
Well the cathedral is MASSIVE. Even with my smallest lens I could only get one of the spires in a frame. And on three sides there is a street and more buildings so you can't go very far back, and on the fourth side there is a small plaza that i shot from. Bottom line is to get the whole thing in a frame you'd need a fish eye lens and to be sitting in a helicopter.
Anyways I used autopano to stitch together 10 different images. It was my first building panorama so I made a lot of mistakes, which is why you can notice that many of the lines are not quite as straight as they should be. I also messed up by putting the camera on auto, so while I should have had 10 frames with the exact same focal length and exact same shutter speed and exact same everything I actually had 10 frames with different everything (the more sky visible in the frame the shorter the shutter speed and the darker the building).
I also forgot to focus to infinity so you'll notice that while I focus in on the lower part of the building the upper part of the building is out of focus.
To top it all off it was absolutely pouring out that weekend, and I took the one opportunity when the clouds had a break to try to get a picture of the cathedral. You can see the umbrellas and drizzle if you look closely. I was trying to make it quick so I think that made things less than ideal.
I actually tried taking maybe five or six other panos of the cathedral but they all turned out really bad -- the pollution made the building much too dark or the building ended up bulging much more...
It still needs quite a bit of photoshop work that I'm not qualified to do but I'm still proud of it. It's a really beautiful building and considering the difficulty of trying to get that shot I'm happy with the results. Next time I'm in Köln I'll know how to get it right.
