2WheelPhoto
- Joined
- Apr 14, 2011
- Messages
- 6,844
- Reaction score
- 996
- Location
- Tampa
- Can others edit my Photos
- Photos OK to edit
(One of our cats has just got sick - the poor little thing threw up all over the bed and woke me up. Funny how it's always me that gets woken up by the cats...)
I thought you meant entrance pupil. I think that learning a few of these optical concepts would not only help you get your thoughts across, but also help with your general understanding.
Anyway, yes, if the entrance pupil is fixed, then the luminous flux is fixed: it's a very simple relationship to conceptualise. The light from an object point spreads out and part of it goes through a hole and then gets focused onto the image. That hole is the entrance pupil, and the area of it determines the rate at which light energy passes through it and on to the image, if it stays in the same location. For a fixed entrance pupil size and location, the luminous flux from an object point will be the same, regardless of the focal length of the lens. (That's why entrance pupil size can be more important than f-number in astrophotography.)
Oops, she's thrown up again. Time to clean up...
(Oh, and if you keep the same entrance pupil diameter - 'lens size' as you were calling it - and field of view, the DoF is indeed the same between formats.)
Coverage is a red herring, and it is also a relephant.
Hope your cats are alright!
Yes, the DoF should be the same between format.
It is the photographer who alter the DoF when he/she try to frame the subject in the same way when using different format. So a head shot photo in larger format should have a shallower DoF than a smaller format (same head shot framing) because the subject to camera distance decrease when shooting with larger format medium.
But that is offset by the larger fstop of smaller formats with the same entrance pupil size.
No its not. if you had pin head size pupil size / entrance compared to big..... nevermind. LoL good luck "getting it"
