Lens flares
AugustMyhrman
South of Malmo, Sweden
When I take pictures of the sun I get these lens flares.. How can I fix it?
Thanks!
I am using Canon 600D w/ 18-55 lens and UV filter
Remove the Sun.
Thats one of the issues of shooting into the sun, IF you are shooting with Nikon you can use nano coated glass. It does help but NOT 100%
Try positioning your camera where the sun does not cast so much glare. Try filters...
Any bright light source in the image frame is going to cause lens flare if the lens you are using has any internal air gaps.
Lens flare is caused by reflections in the air gaps. I don't know of any DSLR lenses that do not have at least 1 air gap in the lens. Most DSLR lenses have several air gaps
Adding any filter to the front of the lens adds an air gap providing another air gap where lens flare can be caused.
The image sensor in the camera is also a source of lens flare in that the image sensor is reflective and there is an air gap between the image sensor and the rear lens element.
Canon lenses also have coatings that help minimize lens flare.
Nikon | Technology | Interchangeable Lenses - The Nano Crystal Coat
Pinhole camera?
I think the lens flare in this photo is a positive aspect of the image.
