Lighting
Bukitimah
Singapore
I took this photo recently. I am using Nikon D300, Tamron 17-50 f2.8 non VR lens and the settings are as follows:
F4.5, ISO 400, 1/250 sec, 50 mm and external flash.
There is a strong morning sun coming at an angle as you can see from the photo. Please give me your advise on how you would set your camera and where I have not done correctly for a better shot.
all you needed here was a little bit more flash power to fill the backlit subjects. Otherwise nice shot!
I would under-exposure about 2/3 of an fstops to have the rim lines making dancers pop. Also, focus needed on dancers, not at the lanterns. But I like your picture Bukitimah.
According to the EXIF data the flash was off, but fill light was needed.
You used Center-Weighted metering, which is good for portraiture, but in a scene with that much dynamic range I would have used spot metering.
I would have metered several spots and then by using flash, controlled the ambient light exposure with my shutter speed, and the flash exposure (fill) with my lens aperture. Being experienced I can do the calculations in my head in just a few seconds. I'm much more adaptable than an inanimate, unable to think, camera is.
The 2 dancers look to be at the near limit of the DoF and are somewhat OOF. Your point of focus was 12.6 m (EXIF data) from the image sensor and the near limit of your DoF was 8.9 meters from the camera. http://dofmaster.com/dofjs.html
Dear KmH, I have switched my external flash on but I didn't use TTL. I am not sure why it did not register the flash. would this PP photo be better?
Hard to say what would make it better, as better is subjective. I would ask myself what I'm trying to show. If its the ladies dancing as the primary subject then they appear a bit underexposed and slightly out of focus. Perhaps either get them brighter or darker.
Because of the lighting, framing and focus I would assume the door is the main subject. But because there isn't a lot of contrast range to make the door pop out your just looking for focus.
But it all depends on what your trying to tell us with the picture.
Those two are yoddling the words filllllllllll flashhhhhh
