Destin
- Joined
- Sep 11, 2010
- Messages
- 3,867
- Reaction score
- 1,386
- Location
- Western New York
- Can others edit my Photos
- Photos OK to edit
Opening the iris by changing the f-stop is gaining more light.
Increasing the ISO is gaining more light.
Slowing the shutter is gaining more light.
Gaining is gaining.
NO, increasing your ISO is not gaining more light, i's increasing the signal to the sensor, your not applying more light when you raise your ISO..
your cranking up the signal, weather you use ISO 100 or ISO 6400, the same amount of light is hitting the sensor..
just by jacking up the ISO does not let in more light to the sensor..
In technical terms, you’re correct.
The exposure triangle is used to teach beginners who don’t need or care to understand the exact science. Let me rephrase so it’s accurate:
A wider aperture will make your image brighter.
A slower shutter speed will make your image brighter.
A higher iso will make your image brighter.
Dude. We all know that higher iso causes degradation, that’s like photography 101. However most of us that are on here have shot with the first generation or two of DSLRs ever made, and with them anything above ISO 400 was absolute rubbish. My Nikon D500 is better at iso 1600 than my D40 was at 200. That’s the point that we’re all trying to make. With modern high end cameras we can now shoot at insanely high iso levels and get photos that were impossible 3-5 years ago, but with the same amount of quality loss that we had back then at much lower iso levels.
As far as delivering a lower quality product to a client if it’s taken at higher iso.. that simply isn’t true. There are times when flash is impractical or impossible at weddings. Do you think my client would rather have a black frame taken at iso 100 so it has no degradation, or a slightly degraded file taken at iso 3200 that clearly shows their first kiss as a married couple?
Pro tip: photography is about capturing emotion and feeling. Clients don’t give a rats ass what iso you shoot at as long as the photos you deliver invoke a positive emotional response.
