Let me simplify,if I may. Not that I am Garbz, but what I think he meant was this: A SSD is a great device when information needs to be accessed from all over the disk, in random fashion, as when used in let's say, a HUGE database, where high-speed, random "seeks" are common, and speed is of the essence. When random, unpredictable, and high-volume requests for data are the norm, then a SSD makes a lot of sense. When random,high-volume, data reads and data writing operations are the normal function, then the SSD really truly comes into its own: think of the New York Stock Exchange's second-by-second data read and write needs...thousands and thousands of read and write operations, from A to Z, all over hell, in crazy, breakneck fashion, need to be noted and updated, in just seconds ALL THE TIME, as a matter of standard operating procedure...this is "random access", and it needs read, and write operations to be done. Very challenging for a traditional patter and head type disk.
However, when what a hard disk is doing is mostly "contiguous" work, relaying data that is pretty much grouped all together, as in "transferring this huge HD movie .avi file from the main drive to the storage drive", or transferring a single folder full of 400 megabyte, poster-sized,.TIF files, then the traditional "spinning disk" type hard drives are really not at that big of a disadvantage. As you can see, the contiguous "write" speeds are virtually identical.
