Low-light High ISO EOS 7D vs d300 test
DukeBoom
While researching for a camera purchase (7D vs d300), I wanted to check the high ISO settings of them, since I'll be using it for low-light concert photography.
I came across this site Canon 7D vs Nikon D300s ISO Test that cross compares them. It doesn't do it in a low-light setting, but the Nikon is CONSIDERABLY noisier than the Canon at settings 3200 and above.
This came as a surprise, since everything I've heard is that they are comparable, and the Nikon may even be better.
What's going on here? Is it because it wasn't a bonafide low-light situation?
edit: Searching around some more, I came across the d7000 vs EOS 60d test, and in this the d7000 blows the Canon out of the water, the complete opposite as above: http://www.cameralabs.com/reviews/Nikon_D7000/noise_JPEG.shtml
Wow that is a big difference, and im a Nikon guy, i might just have to switch to the dark side.
I love my 7D. :D
I love carpet
The 7D and D300s are both introduced almost at the same time. And Canon wanted the 7D to be the best APS-C camera at that time. That is was they took the best of 50D + the best of 5Dmk2 + some of 1D to makeup 7D with several innovation. 7D is almost 2 years old and that is fairly old in camera-age. D7000 is new technology replacing D90 and same to 60D. Which is better? 60D or D7000? I believe its depends at which angle we are looking at as both camera have their own strong and weak points.
The 7D was a brand new camera (launched 9/1/2009). The D300s (released 7/30/2009) was just an interim update of the D300 (launched 8/23/2007).
The D300s is due for replacement sometime this year (D400?).
Expect the D400(?) to have all of the same D7000 features like EXPEED2 image processor, new metering sensor, and focusable HD video - plus much more.
NOOOOO, don't do it!!!! Resist!! hahahaha
If the d400 is similar to the d7000 with a larger weather sealed body, and faster this and that, its going to be a beast.
well then dont get a d300. id like to see a 7D vs a D7000. now you are comparing two modern cameras.
ISO on a D7000 is probably superior than the 7D. i didnt tested both but from the specs ive seen.
pixel density is lower on d7000, iso goes a bit higher. sensor is larger, a bit less mega pixel so i suspect the d7000 iso performance being a bit better on the d7000.
D7 shoots 8 ftps but has only 19 focus point vs the 39 point on the d7000, again for sport i would choose the d7000 even if its only 6fps.
the only thing that the d7 does best, its video..
