- Joined
- Jul 8, 2005
- Messages
- 45,715
- Reaction score
- 14,785
- Location
- Victoria, BC
- Can others edit my Photos
- Photos OK to edit
- Moderator 🛠️
- #16
Here's my general Lightroom workflow:
Level/straighten and crop (if I know for certain the required final image/print size).
Set WB (I use the XRite Colour Passport and/or Exposdisc so this is easy).
Adjust exposure - start with the overall brightness of the image, and pick a point (face, clothing, sidewalk, whatever) and adjust the exposure slider 'til it LOOKS right, then adjust your highlight and shadow sliders, and finally your white and black sliders.
Adjust colours
Bunch of other stuff as required....
When you're adjusting your exposure, as Derrel mentioned with WB, don't worry about the number, slider-position, curve, etc, but get it to look the way you want it. As you do each successive image in the set, choose the same point(s) to use when making the different adjustments, so that if the child's hair has just a hint of blown highlight on the crown, you adjust it so that it has that in each image.
Work on always doing the same things in the same order, and basing them off of the same (or as nearly the same as possible) points in each image. This will help you acheive a much more consistant and professional look to your finished product.
Adjust colours
