nycphotography
- Joined
- Dec 7, 2012
- Messages
- 963
- Reaction score
- 262
- Can others edit my Photos
- Photos NOT OK to edit
I dunno canon so much... I'm mostly Nikon and u43. Unfortunately, a good canon brand TTL flash can run $300 and up. An older model canon, used on ebay should be well under $150. The canon guys should be able to help with specifics.
However you can get a third party a TTL speedlight for $80-90 from a reputable dealer (bounce AND swivel are critical here). You'd have to ask around to see how good these are, but I think these should be really good for the intended use. Vivitar has been around forever and they aren't "crap".
Vivitar DF-293 Digital TTL Auto-Focus Flash f/Canon TTL VIV-DF-293-CAN
or Vivitar DF-383 Digital TTL Shoe Mount Auto-Focus Flash f/Canon VIVDF383CAN
You can start with one, then add a second when you want more advanced lighting.
Smooth White Foamcore is (usually) available at an art supply in 4'x8' sheets (1/4" thick minimum) for around $20-30. Cut one 4x8 sheet down into 2 4x2 sheets, 2 2x2 sheets and 2 16x24 sheets and 2 8x24 strips. You now have a complete set of bounce cards in a nice size for lighting table top sets.
Flat Black foamcore can be used as a gobo. A sheet of it can be cut down using the same plan.
Someone near you should know where you can buy it.... a SMALL LOCAL framing shop may be willing to sell some out of their supplies, or even order some on for you with their next supply order. Set shop sells single sheets... dunno how they ship them
foamcore, bead board, foam board, gator board, Black and Whte Foamcore Set Shop
White ripstop you can easily get online
White 30 Denier Double Silicone Coated Ripstop
$3 worth of ripstop, some cardboard, white gloss and flat black spray paint, and some gaff tape, and you have a softbox. Not a very flexible one for high productivity studio work, but definitely one you can learn with.
http://www.bing.com/search?q=diy+softbox+light
you can make 1/2 PVC frames for $10.
1/2 pvc scrim frame how to - Bing
and use spring clamps to hold it in place
10 piece Plastic Spring Clamp Set - Amazon.com
These light stands are more than sturdy enough for speed lights...
Flashpoint 7.2' Air Cushioned Black 3-Section Lightstand FT2600B
and you can spring clamp bounce cards and gobos to them as well.
Finally, a roll of black and white gaff (cloth) tape to use when sticking things together.
Black Gaffers Tape Small 2" x 12 yd Set Shop
finally... manual triggers.. i have a cheap set and they're maddening... i can't recommend a specific product. But you CAN start with on camera TTL and use the tilt/swivel of the flash with bounce cards for an off camera effect.
All of this will be a learning odyssey and a work in progress. frustrating and rewarding... more frustration early, more reward later.
