RadioGoddess
- Joined
- Nov 11, 2014
- Messages
- 20
- Reaction score
- 0
- Can others edit my Photos
- Photos NOT OK to edit
You just found out that you'll be photographing in a 4 story glass building?? This 'doing a favor for ___' (cousin, friend of a friend) seems to not usually be the best idea instead of referring them to a pro who has the equipment and knowhow to do this.
I would suggest you get over there before Saturday at the appropriate time of day and take some test shots if the venue could let you stop in and do that. If not go early I guess and do some daytime test shots to at least see what glare/reflections you might be getting, and as they're getting ready to start the ceremony and it's starting to get dark do a quick test shot to get set/adjust settings.
With that much light coming in starting out you might be able to use the existing light maybe? Once it's getting dark I don't know what the existing light indoors will be like but think about which way you're facing and the backgrounds to get the ceremony and hopefully minimal glare/reflection if you intend to use a flash. You might need to keep checking and adjusting as the sun goes down and indoor light becomes what you're using. I've found doing events where they raise and lower lights or have spotlights (or a TV crew's lights) that I've had to change and adjust fairly quickly.
Oh yeah -- its my cousin -- (this happened to me once before 20 years ago when my OTHER cousin was getting married - it started out that they were getting married in my aunt/uncles' back yard -- it ended up a full Catholic mass in a church in the round. OY VEY! That worked out okay)
I will be there Friday an hour earlier and will stay till 5:30 if they'll let me - the service is at 5 Saturday.
Thank you !
