- Joined
- Jun 7, 2012
- Messages
- 15,504
- Reaction score
- 7,901
- Location
- Central Florida
- Can others edit my Photos
- Photos NOT OK to edit
- Moderator 🛠️
- #16
What I gain is the flexibility to change the aim point of the flash unit easily and instantly. Try it. You may like it.
try flashes with swivel heads. you may like it.
in an inclosed area bouncing off the ceiling, holding the flash out a bit wont make any significant difference.
im not really sure why you are trying to push some absolute rule with flashes. especially wish such a flimsy example.
im not sure how much experience you have with bouncing flashes off ceilings, but with a rogue flashbender and a ceiling, a flash mounted directly to the camera
is every bit as effective as any direction you could hold it with your hand. for direct flash, meaning not bounced, things are different. for direct flash I either use a flash bracket and a small softbox diffuser, or off camera completely on a stand. (or someone holding the flash on my monopod)
but again, for bouncing off the ceiling, there is no advantage to holding the flash. all you are doing is wasting a hand that could be better used doing other things. like, any other things.
ill give you an example, since this seems to be a complicated concept.
this shot was taken at the Tampa aquarium. above the bride and groom are blue and purple spotlights.
this was shot with a SB700 mounted directly on the camera, pointed up with a rogue flashbender in front directing the light up and backwards.
wedding by pixmedic, on Flickrthis shot was taken with the same flash and rogue flashbender, but with my wife holding the flash on a monopod camera right.
the same blue and purple spotlights apply.
DSC_0169 by pixmedic, on Flickras you can see, the same results were achieved with both methods. the biggest difference being that instead of having to deal with someone holding a flash, and where to put it when im not using it, i could simply put the flash ON THE CAMERA and bounce it of the ceiling and literally get the same result. so much easier for me.
if you want to hold your flash in your hand, theres nothing wrong with it if that is your preference....but it seems a tad irresponsible to tell people they should never put the flash directly on the camera when it is obviously a perfectly feasible technique.
