Nikon or Canon??
Status
Not open for further replies.
Either.
They are both top notch as used by 99% of pros. My kit is all canon, That is because when in your position, I went to my local camera shop and picked up the two cameras that were in my price range. The Canon felt better, so I bought it. It was THAT subjective. You should try it. Buy the one you are most comfortable with. (And have some fun in the camera shop while you are at it !!!).
some good replies guys im going to the local shop on Monday to get some ideas
thanks
I think the MID-level Nikon bodies are the best to buy. The entry-level Canons and Nikons are what I call "two button cameras", meaning they have ONE control wheel, operated by the thumb, and then a top-deck-mounted, very small button that must be pressed and held while turning the thumb-operated dial or wheel--in order to open the lens aperture up or to close it smaller. That system sucks, and impedes learning, in my opinion.
SO, that means a Nikon D90 or D7000 is the camera. Again, NIkon works differently than Canon. Nikon has a thumb wheel, and an index-finger operated wheel. The thumb wheel controls the shutter speed in all exposure modes. The front wheel, operated by the right index finger, is always for the LENS, in all exposure modes. With Canon's, those controls flip-flop functions, back and forth, back and forth, back and forth, depending on WHICH SPECIFIC exposure mode the camera is in. So you are not always absolutely 100 percent positive which control will perform which function with a Canon, since the functions DO SHIFT as the exposure mode is changed. It's as if the gas and brake pedal functions were reversed--depending on WHICH of four gears the car is in...that is Canon's idea of how to design a camera. I find that idiotic. But then, they made the entire control ethos and mechanical design up in one year, and have remained with it for 25+ years. Nikon took almost eight years to figure out how to shift from analog to digital control systems.
With Nikon, it's not like that. The thumb wheel ALWAYS maintains the same function, as does the front wheel. There's a reason multi-platform shooters often express an ergonomics advantage to NIkon bodies over other systems. I own several Nikon bodies, and now have two Canon d-slr's left...I prefer the Nikon system quite a bit, in terms of operation. I have given Canon a fair, five-year trial, with enough pro-level gear to evaluate it fairly, plus the older 20D, and Rebel XSi (since given away to my niece). Again, the ENTRY-LEVEL Canon's I find not as compelling as the entry-level Nikons, and I think the MID-LEVEL d-slr is the one to buy, learn, and use for 4-5 years. The Nikon D7000 would be my suggestion for a first camera that ought to last five solid years before you feel you have mastered it and it is no longer competitive.
Its ultimately going to be up to you, and how it feels in your hands. Do you have friends that shoot Canon or Nikon? Consider the possibility of sharing lenses.
hRon can you explain that statement? DO you mean using adapters? Nikons lens lineup goes way back and most all lenses manufactured in the last 30+ years will fit a new Nikon.
When I first set out to get my first DSLR I end up with Nikon because just feel better in my hands and I like the way they placed the bottoms.
I'd say neither. Try Olympus. It's has very good entry level camera with decent kit lenses.
Yes Trever, with adapters. There are lotsa canon users on the manual focus forum using legacy lenses of several mounts. Not as easy as me using a M4/3 camera though.
Mirror-less is the future.
Because of the "Flange to Focal Plane Distance" of the Canon EOS mount (44mm) is shorter than Nikon mount (46.5mm), so those Nikon manual focus lens can be mounted on the Canon EOS camera with an adapter without any optics inside the adapter and still able to focus to infinity.
He might also be referring to the Canons metering any lens put in front of them. Only certain Nikons can do that.
Am I missing something? Whether Nikkon has more than pentax or Canon. do they all not have enough to cover every requirement. Canon (And I am sure the others too) Do L series pro right down to efs Kit lenses. So just find what you are comfy with. BUT if it bites and you want to go FULL SPEC then a canon or nikon body will have you on the bottom rung to start with
Figure out what features you want/need, look around the various brands like Pentax, Nikon, Cannon, Olympus, Sony, etc and see which one best fits in your price range.
Status
