coastalconn
- Joined
- Mar 24, 2012
- Messages
- 3,594
- Reaction score
- 3,636
- Location
- Old Saybrook, CT
- Can others edit my Photos
- Photos NOT OK to edit
- Thread Starter 🔹
- #16
I got better results today, so the quick answer is hell yeah!Kris it really comes down to you, do you like it?
Sharpness is very subjective. I've noticed that by the comments on my FB page. Seems 50/50 what people thought was sharper..I can't tell which lens these are shot with, even after reading a couple times. It doesn't matter, the photos are fine.
You could be seeing sample variation, or cleaner air one day then another, or more contrast from a softer lens, or any number of things. Subjectively 'sharp' correlates only loosely with the relevant properties of the lens MTF.
Thanks Sharon, I should get a 600mm PVC pipe and a few coke bottles and see what I can work outTwo things.
1. I don't know if it's sharper than the 120-300 or not, but it is plenty sharp enough. If I could achieve pictures like that, happy would not even begin to describe how I'd feel. But then, I've always said I think you could get sharper pictures using a Coke bottle for a lens than I can get with my Sigma 150-500. That Common Yellowthroat is just spectacular.
2. That last one isn't a Mockingbird. It's a Gray Catbird. And a nice shot of it, too!
WTH is a Flickerism?I love number 5. The DoF is a tad less than the bird in one or two, but I'd expect that. Are the "fuzzy-wavy" areas on top of the egret's neck (not the reflection) stray feathers or a Flickerism?
After reading your review I would have to agree with you that the Tammy appears to be sharper. I don't think it matters though when it comes to the lens that you have on your camera body and your ability to get so close to the birds. I think you could take any lens and produce beautiful images with it. It's like many have said here before, it's not the gear, it's the photographer.
Edit, I also noticed that the Tammy seems to be brighter.
Thanks everyone for all your thoughts... At some point I will do a real test on a pod with live view. But it might be a mute point now. Think I figured a few things out..I think the key is put the birds down and pick up a dull brick wall and some ideal lighting and a tripod.
At least for a pure sharpness test - yeah its dull, its not going to be anywhere near as pretty as the fantastic bird photos you get. But its informative and isn't going to be swayed by things like shifts in settings, lighting and fatigue.
That is a good part of the issue I think..The light on this day was beautiful and crisp, and that ALWAYS makes a lens appear to be sharper and more-contrasty. I dunno...I looked at the other thread and on the POSTED sign, the Tamron appeared to produce the better image quality. I am wondering if on duller-light days, if the Tamron just doesn't look quite as snappy as it does on a bright-light day?
Matt, according to Nasim's test the Sigma 120-300 with 2x at F8 is as sharp in the center as the 300 F2.8 VR, so it can be very sharp, but focus accuracy is a big deal for sure. I think analyzing my test I came to the conclusion that I was struggling in post because the Tamron produces more shadow noise, I'm sure it is one of those sharpness things, so I went with ETTR, and less processing and got better results. I think the Tamron at 600 easily tracks better than the Sigma with the 2x TC..I guess i would expect the tamron to do better than the sigma with the 2x on it. I guess it comes down to the focal distance you use the most of. If always over 420mm ish than the sigma and a 1.4 converter cannot be used and the tamron is probably going to be more contrasty and more accurate at auto focusing.
I think there are very few lenses if any that can match performance of a lower end zoom like the tamron 150-600 when used at the same focal distance with a 2x tc. Maybe the prime 2.8 like the 300mm or 400mm or 200mm f2.0. But even with them i found af to be not very accurate at times. But when it was accurate it was plently sharp
