Neuner
- Joined
- Mar 14, 2007
- Messages
- 314
- Reaction score
- 0
- Location
- In my home.
- Can others edit my Photos
- Photos NOT OK to edit
I hope it works for you. When you take some shots, post them. We would love to take a look at them.
Your camera uses a sub-frame image sensor (the image sensor is less than the full frame of a 35mm film exposure) so you'll need to understand how your D100 receives the light from your Sigma 105mm lens. It will simulate a longer lens; additionally, it will prevent vignetting on cheap lenses because what would have been the corners of a full-frame sensor are actually cropped off by your D100.
Just something to be aware of, especially if you're actually desiring a true 105mm representation.
The Sigma lense I've bought is made for digital, so luckily I don't have to think to much about the frame size of the sensor. I have a 35-105mm where I keep forgetting this... Thanks for your advice. =)
I feel this needs clearing up... the camera does not have a sub-frame sensor. It just has a smaller sensor than 35mm. To say it has a sub-frame sensor is like saying 35mm film is a sub-format because it's smaller than 6x6. A 105mm will not simulate a longer lens, and it will give a true 105mm representation... it will just appear longer than if you used it on a 35mm camera. I know I'm just being pedantic, but there's a reason, because I think it can cause confusion, for example...
... The lens being "made for digital" in this case only means it is optimised for digital sensors (in terms of lens coatings). It will still work with 35mm film too. More to the point, you have to think about the sensor size (or not think about the sensor size) in exactly the same way as with any other lens... because a 105mm lens on your camera is a 105mm lens, regardless of whether it's made for digital. So your 35-105mm lens, when set to 105mm, gives exactly the same angle of view as your new 105mm lens.
OK, this needs further clarification, too. The D100 DOES have a sub-frame sensor in the sense that the image sensor is smaller than its film equivalent. Apples to apples (35mm digital to 35mm film), not apples to oranges (35mm digital to 6x6 film).
All it would really indicate for me is that I'll have to stand farther from my model ... (This is why I'm considering a 50mm lense as well, to be able to work with a comfortable distance to my models when working with bouth head/sholder shots and full body.)
:thumbup:
Sounds about right! You need a fair bit of room to work with a 105mm, but it's good for head shots. For full-body shots a 50mm or possibly wider would be good.
Hope my long-winded explanations managed to clear things up rather than confuse them further![]()
The 105mm lens will give an angle of view of around 23° on the 35mm format, or a smaller angle of view of 15° on your D100.
I need help with this actually. It seems to me that a lens is going to give a certain angle of view regardless of the size of the sensor. With a smaller sensor and the same angle of view, a smaller portion of the scene is captured, which in my head makes sense as to what would be going on with a digital sensor. Does the angle of view change from the centre of the lens to the outside, giving a different angle of view at different points? Are the depth of field and foreshortening characteristics the same or different with the same lens on film and digital? Thanks.
Dave
