Netskimmer
- Joined
- Jul 23, 2009
- Messages
- 1,392
- Reaction score
- 229
- Location
- North Carolina
- Can others edit my Photos
- Photos OK to edit
I got my teleconverter today, a Rokinon auto tele converter 2x N/AI. Not sure if this is a problem or of the thing is supposed to work this way but I cannot adjust the aperture on my lenses from the sub-command dial while using it. It has a lever in it that connects to the aperture lever in the lens and I can widen the aperture by connecting it to the lens and maipulating it's lever and I can press the DoF preview button and see a difference so everything is connecting on mechanical level, but the aperture is set at F0 in the camera and cannot be changed. It's basically treating the lens as a non-CPU lens, mainly because the the tele-converter doesn't have contacts to transmit data between the camera and lens. I can set the max aperture in the non-cpu lens settings menu but his has no effect on the actual aperture used to take the image and what I see when I press the DoF preview button does not change. I there a way to alter my aperture setting or do I need to use a lens with an aperture ring?
