Post your favorite shot from your most recent roll
Her Highness. Captured on my new-old Mamiya C330 with 80mm at f/2.8, captured on Kodak Portra 400. Digitally scanned with Nikon D5300 and converted with Negative Lab Pro.
(PS- went ahead and used my 9 month old chemicals, but I processed at 110 degrees instead of 102, to compensate for any fatigue in the developer).
Not my most recent shot, it's my most recent scan. This is Ward Charcoal Ovens State Historic Park, near Ely, Nevada. I created this image hand held with a Hasselblad 501 C/M and 60mm CF lens. I used Ilford Pan F 120 plus film, shot at 25 ISO and processed for normal 50 ISO. I use Kodak D-76 mixed 1:1, develop for 10.5 minutes (as per box), after a constant 30 second agitation, I gently agitate three rotation/inversions every 30 seconds. After each agitation I set the tank down in the sink with a purposeful tap to let loose any air bubbles that might be, then give the tank a good spin in place, this helps with density changes at the edge of the film closest to the reel. I mix my own stop bath from 100% glacial acidic acid down to 28% for a master solution, but mix my film stop bath very weak, this helps to eliminate any pin hole marks from too rapid a stop action. Then a normal mix and time of Kodak Rapid "A-B" liquid fixer. Wash in archival film washer, hypo clear and hang to dry.
I'm scanning my film using an Epson V-700 photo scanner, with a betterscan scan bed (focusable anti newton glass frame), this allows you to focus the negative or transparency and holding it flatter with greater precision than the standard film holders yielding a much sharper overall scan. I'm using Silverfast 9, Ai Studio for software, IT8 calibrated (moot point with b&w). I make scans at or near the maximum the scanner is capable. This scan from a two and a quarter negative is 60 x 60 inches at 300 dpi, with layers (levels/curves) is a 2.66 Mb file.
