PP C&C
mfrankpdx
I wasn't able to go out and photograph today, so I stayed in all day and played with Photoshop.
Here's the original, boring, average photo. At first I picked this one for it's ease of editing, then discovered getting around the grass in the foreground was actually pretty hard.
Here's the clouds I wanted to add to it. Again, a very basic photo for easy editing.
Here is the final result. Although not very interesting, I'm pretty happy with results when the before and after are compared. Blown up to 100% it's easy to see some messy areas, but at this size I'm satisfied.
Comments welcome!
How'd you do it? Layer mask? It looks like it wasn't very easy (the busy areas around the trees look like a nightmare..).
Nice job.
Cool, I would recommend trying to figure out a way for the clouds to be reflected in the water. Great job!!
Nice job.
Yep. When I created the mask around the trees, I used the "refine edge" button and added a few pixels of "feathering".
What about the clouds are reflected in water? how was that achieved??
Again using masks. I created a mask of the water with a layer of inverted clouds below. I then adjusted the opacity of the water mask until it looked realistic. When creating the water mask, I didn't need to be very accurate around the weeds or the reflected trees because the opacity was set pretty low.
I'm sorry if some of this isn't clear. I've never read a book or taken a class on photoshop, so I'm not sure if I'm describing everything I did with the right terminology.
I never took photoshop classes either. I learn everything from trial and error, google, and youtube. Keep it up!
