Not sure why the above is in bold and will not respond to efforts to edit it to normal typeface. ISO, 500...that makes the flash need to be "less", and also makes the impact of the daylight "stronger" than at a lower ISO value. The slowish shutter speed of 1/45 second outdoors is bordering on what is called "dragging the shutter", meaning slowing the shutter speed down, in order to pick up light from the daylight, in the background, behind the range of the flash. The lens aperture of f/3.5 is fairly wide, and allows in a lot of light, especially in combination with a 1/45 second speed AND an ISO value of 500.
Cloudy Weather white balance makes things look a touch "warm". Normal contrast, normal saturation, and HARD sharpening with flash make things look very crisp, very sharp. Your rendering is NORMAL, so no over-saturation or clown-colors. Metering mode was SPOT, and the spot happened to be on a good location.
All in all, this seems like an Aperture Priority AUTO Nikon D200 daylight flash shot, made with a fully distance-aware camera, with a fully color-aware light metering system, and fully color-aware flash metering system, made with Minus 0.7 EV dialed into the metering system. I honestly believe that using SPOT metering in this type of situation can lead yo HIGHLY variable results, and would generally suggest that you NOT shoot flash photos using SPOT metering unless you're always, constantly aware of where the AF point is located. SPOT metering can cause undue influence to very small, minor subject differences, and if your flash exposures Yo-Yo all over the place, SPOT metering can sometimes be the culprit.
