I think what had happened is a lot of dusts in the sensor. I keep switching lenses a lot. I have been using a lot of Sensor Swabs and Visibledusts. No matter how many times I clean it, there is away dusts in the sensor even I use a rocket air blower. When I use the sensor brush for the first time, it got worse, because the dusts accumulated in the edges of the sensor and spread out. I have to use a sensor brush to brush several times to get the sensor clean. It takes me a while to get all the dusts out.
Tecboy, I think your best bet at this stage would be to have the camera cleaned professionally. Then once you get it back, and forgive me if this seems a little direct, leave it the hell alone. The only time you should really consider trying to clean it again is if you actually see something on the images themselves, otherwise just leave it be and let the camera's auto cleaning system do it's thing. In the meantime, if you think you might be wanting to attempt doing this again yourself, find the cheapest low end canon DSLR you can find used and buy it. Then use it to practice with. Just my two cents worth of course.
