Question on wireless trigger for Neewer flashes
curly
TPF Supporters
Memphis, TN
Hi all,
I am looking at the Neewer VK750 II flash and am wondering which wireless triggers should work with this flash. I noticed that the info about the flash says it already includes wireless capability.
Does this mean I can just buy a transmitter, like the Youngnuo YN-622N-TX or others, to trigger the flash without have to get the receiver units for the flash?
Sorry if this is a newb question, but I was not sure if the Neewer flash should work with certain transmitters or not.
Thanks
Unless the specs specifically state that it can be used with a certain brand of trigger, then it's most likely a proprietary. You'd have to buy that brand of transmitter to trigger it.
Triggers aren't cross compatible, so you can't use a Radio Popper with a Pocket Wizard. However, some brands like Profoto and Dynalite have built in Pocket Wizard triggers; those brands are also clearly labeled as being compatible with a different brand of trigger than the manufacturer. I doubt the brand you're asking about is compatible with anything that's not proprietary though.
I think this is the key phrase, "Wireless triggering distance: 20--25m indoor,10--15m outdoor" it's either compatible with Nikon's CLS, in which case you're out of luck as the D40 can't be used in Commander mode, or it's simply got a built in optical trigger, in which case you're fine, as all you need is the pop-up flash to act as the trigger. Either way however, I would recommend buying a radio trigger such as one of the Yongnuo line. Optical triggers (including CLS) rely on line-of-sight, and that's not always ideal for setting up off-camera flash lighting.
