Buy a second body. That'll get you a whole extra, complete buffer.
The D7000's issues with write-to-card performance are right out there in plain sight. All the serious reveiws of the D7000 mention its buffer limitations. The D7000 is a high-level CONSUMER body.
If you need a camera with a deep,deep buffer, then you need a professional camera. Or a semi-pro body. Or a second, consumer-level body.
That is not likely.
The camera's buffer write speed is usually the limiting factor, not the card speed. Card speed is more critical for uploading to your computer, than for use in the camera.
Most cameras cannot write any faster than what a class 6 SD card can handle, so spending extra for a class 10 card trying for faster in the camera write speeds would be a waste of money.
Well not in all fairness, if the card is a128 meg card manufactured 10 years ago or longer then it might be the limiting factor. If not you are dead right.![]()
It,s not just thenclass of cards but the hardware contained within. Good resource on card read and read.write speeds. Rob Galbraith DPI: CF/SD Performance DatabaseI still have yet to nail down what is 'fast'. When I upgraded from a D60 to the D7000, I went from 2g unclassed cards to 16g class 6. The new cards totally sucked compared to my 6-y.o. unclassified cards. I only use them (the new 'high-$ cards') for transferring files between computers now. I have also been hoarding 16g Class 10 cards now, since they clear the buffer the fastest so far.Well not in all fairness, if the card is a128 meg card manufactured 10 years ago or longer then it might be the limiting factor. If not you are dead right.![]()
