qleak
- Joined
- Dec 11, 2013
- Messages
- 629
- Reaction score
- 183
- Location
- Ohio
- Can others edit my Photos
- Photos OK to edit
Okay after a couple of hours of pure goofing around, I think i finally understand something about flash photography. Here's my realization:
- Shutter speed is all about controlling the ambient exposure. The slowest duration flash for an SB700 is 1/1000 but it's T.1 ~ 1/305, since the sync speed is 1/320 max before going to high speed sync mode, you really won't be freezing the action any better than the flash.
- Below both are f8 1/16 manual flash. This is 4 stops lower than 1/1 power which has a guide number of 92ft so it's equivalent to dividing the GN by a 4 stops lower f-number f32 92/32 ~ 2.9ft. I set the flash on a stand 2 ft away. Picture 1 is 2" exposure Picture 2 is a 0.1" exposure. The exposure on the plant is of course changed a bit by all the extra ambient light in #1.
- The aperture changes the guide number GN (the effective range of the flash), and the ambient exposure.
- ISO also affects the guide number, but every stop change in iso is sqrt(2) change of GN.
- Distance from flash to subject should be less than or equal to the guide number. GN mode on a nikon flash is really handy for getting a baseline on this.
I wanted to use my old gossen luna-pro f but the flash mode does not work correctly! - ND filters can be used to widen open up your aperture while maintaining the same ambient exposure.
- Both of below are shot at ISO 100, 1/60th shutter. Picture #1 is at f8 and picture 2 is at f2.8 with a 3 stop ND filter. I think i stacked too many filters and introduced some vignetting too.
