Slowest SP hand held you can shoot?
hamlet
Belgium
What is the slowest shutter speed you can shoot at while standing hand held? Also feel free to share how you can achieve this amazing feat.
Depends on you. I've gone as low as 1/4s for a statue at night before and did ok.
I actually shot this HDR handheld ;)
Does moving instead of standing handheld count? ;)
The slowest i can shoot at is 1/30s without vr hand held. For me i just get balled up like a hedgehog and shot on continues mode when i'm done exhaling. From then on it is picking the sharpest i took. :lol:
Sure, we can only benefit from your knowledge.
Usually not slower than 1/60 and I prefer not to go slower than 1/125. If I'm losing light late day and shoot slower than that I get positioned and braced to try to keep the camera steady. Taught myself that shooting sports anyway, I sometimes stand feet somewhat further apart, knees in a little & heels out, elbows in, shoulders back and hips forward, etc. - or is that doing the Time Warp?? Hard to describe, and anyway my weight isn't going to shift over my hips the same way as you men so what works for me might just work for me! lol
There's a guideline created in the days of 35mm film cameras. The idea is that the "average" person who is using good techniques to hold the camera and a good stance and actually trying to be still can probably hold the camera well enough to use a shutter speed equal to the inverse of the lens focal length. E.g. at 50mm then 1/50th. At 200mm then 1/200th.
But this is a "guideline". Some people are able to do a bit better... and some people aren't even able to be this steady.
Also it gets complicated with crop-frame cameras because you have to multiple the focal length by the sensor's crop-factor (usually 1.6 for Canon and 1.5 for Nikon).
Feet should be spread apart so you have a wide solid stance with a good center of gravity (e.g. don't "lean"). Your left hand should palm the camera body and lens in an underhand grip with your left elbow tucked in to your stomach so you are supporting from below and your forearm braces the camera. The camera is pressed to your face -- not hovering out in front of you. You can find videos on good camera holding technique.
Also if there is something you can lean on to brace yourself or your camera... then lean on it.
Handheld - 270mm, 1/6 second, f/5.6, ISO 400
Posture, bracing, stabilisation, technique and the degree of sharpness you consider acceptable all have a factor but the effective focal length is also VERY relevant.
I've recently managed to pan a 750mm EFL at 1/180s with little or no shake https://www.flickr.com/photos/petrochemist/13548301284/ at more normal focal lengths I've managed down to ~1/4s on occassion. Going this far beyond the rule of thumb will involve a lower suscess rate, but with digital it doesn't cost anything to try.
So anyone have a sharp shot taken hand held with an 800 F/5.6 at 1/100 ?? Would love to see one :) :) :)
Danny.
how about 200mm at f/5.6 and 1/20?
I was testing the effectiveness of the VC.
Going through some older shots here's one at ~1/3s where I didn't have a tripod available.
EFL is 37mm, IMO the lack of dynamic range is much more of an issue than any shake.
