CCericola
- Joined
- Jan 5, 2011
- Messages
- 1,922
- Reaction score
- 567
- Location
- Washington
- Can others edit my Photos
- Photos NOT OK to edit
Sure, not looking for the real colors. Just a half ass thing. Blue sky and flesh color. If something was off color, click on it for a pallet of colors to choose from.
Software should be able to figure sky, people, maybe grass, streets. buildings, cars. Don't like a blue car, click on it for red or pink. But software would give you something to start with.
Sounds like you've identified a niche market. Start writing the script and fill it. In no time, you'll be hobnobbing with the Vanderbilts and lunching with Gates.
What Sparky is saying is that it is an enormously difficult problem that is only handled at this time by dedicated hardware and software issues that can do sophisticated pattern matching.
A computer would have to isolate something from a digital image and match it against a pattern for all possible items in every possible configuration.
Not simple or easy - even with dedicated fast hardware on a limited set of potential items in the field of view.
With no limit of what is in the field from grass to cats to airplanes, the number of patterns that would need to be scanned is astronomical.
........ I figured if they could do it with movies, then still pictures should not be that hard.
A major difficulty with this process is its labor-intensity. For example, in order to colorize a still image an artist typically begins by dividing the image into regions, and then assigning a color to each region. This approach, also known as the segmentation method, is time consuming, as the process of dividing the picture into correct segments is painstaking. This problem occurs mainly because there have been no fully automatic algorithms to identify fuzzy or complex region boundaries, such as between a subject’s hair and face. Colorization of moving images also requires tracking regions as movement occurs from one frame to the next (motion compensation).
.......... That would be sort of like if Newton/Leibniz had invented calculus to figure out how to properly toast bread.
I don't know. I'm not much of a computer guy. Was just asking and hoping something was out there. I figured if they could do it with movies, then still pictures should not be that hard.
Soooo.....
I found this cool collection of molested materpieces...
19 Legendary Black & White Photos Colorized Using Photoshop
with this picture...
http://cdn.bitrebels.netdna-cdn.com...Legendary-Photos-Colorized-In-Photoshop-9.jpg
Anyone knows who / what / where / why this picture is? I've seen it before, but I can't place it.
Hey, that looks nice. Will check it out.
Thanks!
