Some HDR Scene's of Cebu
mikelmartin
Philippines
The sun has not shined for the last couple of days. So this set were shot under gloomy and gray skies.
Edited ... Thanks to the advice of Provo.
You have a dust spot all 3 of these images appear flat like a standard image.
Thanks... Will try and do better next time.
Oh.. Thank for spotting my dust spots will try and clean my sensor today
Omg... When looked at it at my monitor it looked fine. Then when I viewed it on my iPad it's totally wrong. Oh man!
Just use the spot healing brush to clear out your dust spots in photoshop
The first two images have too much yellow tone in them use the hue/saturation adjustment in photoshop and bring the yellow down by 10% at least
Also a few more underexposed shot's would've recovered the sky since it's blown out and the details are lost. When processing your images take your time in photomatix sometimes when you think you are done look away from your shot for 2 minutes or so and then come back to it let your eyes re-adjust often you will notice little areas to correct if not then you did the best you could. I practice this alot sometimes I say ok I like the image but then I look away and come back and say ok I have a little too much saturation.
Hi I edited it a bit.. How does it look now? Hehehe :D. Yep I'll try shooting with more underexposed shot's.. Thanks Provo!
the re-edit of the 1st looks a bit better keep on working & learn as much as you can you will bump up your game in time.
Idk what you used, but the best HDR program I've used is photomatrix.
Thank you so much provo.. and I will certainly put your tips into use.
Hi.. Yes I heard photomatrix is the best HDR Program. Right now I am experimenting with photoshop HDR Merge.
Thanks,
Mikel
Thanks,
Mikel
Ahh Good ol Photoshop MikelMartin make sure you swing by Jason's website he has tutorials that will help you out
There's a Photoshop Cs5 hdr merge feature worth checking out for you.
Also try out different software some offer trials such as Dynamic Photo HDR 5 and photomatix and nik hdr efex
- JHPVideoTutorials - Free Photography Tutorials
