- Joined
- Oct 16, 2012
- Messages
- 14,632
- Reaction score
- 7,563
- Can others edit my Photos
- Photos OK to edit
- Moderator 🛠️
- #16
Not terribly surprisingly, the welding glass is crap. * It is 16 stops exactly as I suspected, which is nice, but... * You cannot recover colors. It blocks everything but green so completely by comparison to green that the other two channels look like the most heinously jpeg artifacted garbage imaginable. You are pretty much obligated to dump both channels and make the green black and white. * Even then, it does some strange stuff with images across the frame. Dead center is usually normal looking. As you go further out to the left or right (it seems to be a linear pattern not circular), the image starts splitting up and down. Like, it looks as if you jostled the camera up or down halfway through the exposure and it ghosted half and half up and down. But only on the sides of the image. Esentially impossible to get a sharp image end to end. * Even though I glued it to an empty filter ring it still flares weirdly, so it's coming through the glass with the weird flares, not just from the edges. Gavin is sad. Back to resigning myself to shelling out way to much money for gray glass.
I admire your effort. Why did you go with green?
