- Joined
- Oct 3, 2013
- Messages
- 11,518
- Reaction score
- 4,788
- Location
- Louisville, Nebraksa - United States
- Can others edit my Photos
- Photos OK to edit
As you can see both do very well at low iso and at 6400, while definetely the quality is less, its at a level that could only be dreamed of a few years ago- both are good choices, but having a friend that has nikon should pull you a certain way
Hmm...is it wrong/weird that I like the photos taken with the 7D better than the 7100? Haven't looked into the 7D at all.
No not weird at all. That's the way it is. The 70d should be similar if not slightly better than the 7d. I would advise not to judge on them few vastly different samples and maybe to look at Flickr and check out the group's of photos for each camera also. Lots say that not comparing like photos for like in a set up environment doesn't yield accurate results, but real pictures beat charts in my book anyday
Well, first you have to be sure your comparing two photographs shot under exactly the same conditions with the same subject matter, same composition, same lighting, etc, using two lenses that are on par with one another and that both photos are cropped in almost the same fashion - otherwise your test becomes entirely too subjective.
For example, if I take a D300 12mp, a D5100 16 mp, and a D5200 24 mp and shoot all three in good lighting under the same conditions with the same 50 mm 1.8 AF-S G lens, well if I don't crop any of the photos you'd be pretty hard pressed to tell which was which. Take all three cameras into a situation where the ISO has to be raised enough to get a proper exposure - and the picture taken by the D300 is going to stand out like a sore thumb.
If I take all three cameras and shoot with my 70-200 mm at a distant subject, well again in good lighting conditions with no cropping you won't see a huge difference between the photos. Take those same photos and crop them heavily? Suddenly there is a major difference in IQ between the three, even using the same lens under the same conditions.
If I take pictures using say the D300 with a professional grade fast lens under poorer lighting conditions and the D5200 under poor lighting conditions using a slow, commercial grade lens and again, the D300 photos under the right conditions will turn out better than those you'll see from the D5200 not because of the body or the sensor but because of the lens.
So really comparing sample images shot by two different cameras under shooting conditions that vary between shot to shot is just not going to give you an accurate picture, not unless your comparing tons and tons of them and carefully examining the EXIF data and being extremely careful to make sure your comparing apples to apples. Even then it probably still won't give you the full story.
If you looked at a set of photos where none were cropped then the differences between images shot on a D5100 and a D5200 would be barely noticeable if at all, assuming again the same level of skill of the photographer and your shooting in conditions where the two cameras are relatively equal. But if you look at some of the images I've shot with my 5200 you'd have no way of telling that you could never get an equivalent image out of a D5100 because you have no way of knowing how much they had to be cropped to get the end result I wanted.
So no, I don't consider comparing a few sample images from two different bodies to be a good methodology for deciding which camera you should ultimately go with, because there are just entirely too many variables to consider. Especially when you add in the fact that the subject matter might be more appealing to you in some images than in others, which has absolutely nothing to do with the camera body at all.
OP, it's your money and your free to spend it however you wish, but I strongly recommend you consider what types of shooting situations you'll find yourself in most often and use that to determine what qualities in the camera are going to be most beneficial to you.
Just my 2 cents worth of course, YMMV.
