- Joined
- Sep 2, 2005
- Messages
- 14,455
- Reaction score
- 3,328
- Can others edit my Photos
- Photos OK to edit
The thing is "technical goodness" isn't even a meaningful phrase. Any technical element can be used powerfully in either direction.
Technical elements of photography are just effects that can be applied. Put the focus here, put it there, you get different images. Warm colors, cool colors, you get different images. Sharper or softer, different images. These images all feel different to the viewer and they either work or not. The effect either supports the image and the ideas in it, detracts from them, or is neutral.
The only real difference is whether you can do it in post. Sharper is better up front not because sharper is better, but because you can't add sharpness in post. Youcan add the opposite of sharpness.
As technology advances, the list of technical stuff you can change in post gets longer, though. See Lytro cameras, light-field tech, for a contemporary example.
Technical goodness... Is really the skill necessary to execute the photo you want in the way you want it. You bring up a great point though... If I want overexposure in a certain part of the photo I need to know how to do that to execute on my artistic vision... Which IS what I'm saying, except that it also brings about the point that something that would traditionally be called "a mistake" and panned would actually be intentional. Ergo a "bad" image can actually be a "good" one ... If the artist intended it as such and the message is effectively carried.
Ugh. That hurts my head.
Good thought provoking comment as always, amolitor.
