The Coffee House
Agreed. I replaced my rotors last year by myself. The mechanic wanted $350 for the front two. Hah.
With most vehicles it's a pretty easy job, something you can do in the driveway with some basic tools and a jackstand. Only one's I've ever found that were really bad were Mazda, those things were nearly impossible to get off.
Or you can just drive out to Detroit ... Gary is confident that JC would be more than happy to oblige. Hell, he'll probably meet you halfway.
Morning, hosers! I hope everyone's hump day is going well so far.
On the subject of old cars, my 2001 Civic with about 197K has front brakes that chatter, result of not having the rotors ground down last summer when it got new pads. I didn't figure on having it very long, but now it looks like I may keep it until early next year. The chatter is getting a little worse (happening at lower speeds and a little more pronounced). Am I in for some sort of brake catastrophe soon or can I ignore it for a while? The car doesn't get much mileage, probably only 3K/yr at this point.
That's not necessarily (in fact probably not) the result of not having the discs turned, 'though it could be. It could be an indication of front spindle wear, pad failure, wheel bearing wear/failure, or disc warp as a result of hard breaking followed by cooling (stomping on the breaks and then driving through a puddle). Regardless of the cause however, this is NOT something to ignore. Your front breaks typically provide 60% of your stopping power, and when they're "chattering" they provide VERY little stopping power, possibly as little as 20%.
BUT... did you do all the other things that the mechanic would have done for $350? Check the piston seals, lubricate the slide pins, clean the calipers... I also STRONGLY recommend bleeding the lines each time you service the breaks to get fresh fluid down to the business end.
I was surprised at how easy it was. The only tool that might not be in the typical tool chest that I used was a torque wrench.
They also wanted $70 to change my in-cabin air filter. A $15 part that takes less than 5 minutes with no tools required. Rip. Off.
Most of the simple stuff I do myself, if it's something that's going to require a ton of work or specialty tools I'll end up taking it to a mechanic. That and anything with belts. I hate belts. Lol
I did! It was a fun learning session. I never realized I knew so many curse words... :boggled:
There it is. There is the right way and then the driveway. All those steps guarantee safety and are critical.
It's easy to do it the right way in the driveway, but often people forget that there's more to it than pulling the wheel and swapping discs....
Agree, 100%.
Yup, he was wise. I finally sold my wife's 2012 Buick Enclave a few days ago. Craigslist finally came through but the scum that comes with it is not desirable.
He was also a mechanic :)
@ Leo: Gary just purchased a used car for Mary Lou's son. We delivered it to a high school auto repair/mechanic class and they went through everything and repaired it all, for only cost the cost of parts (the school gets a discount on the parts). The school's program is taught by certified mechanics most of the teachers own their own shop and the class is to prepare the kids for certification. Send Lucille to school.
Buzz and I do the work ourselves. He helps me with the more complicated stuff.
@robbins.photo , @Gary A. , @waday
Thanks, guys. I need to get it inspected by next month so I guess I'll bite the bullet and have them do the rotors.
Keep the receipt. If you decide to sell the car, use that as a selling point - I just had the brakes redone and new rotors installed.. blah blah blah.
Does wonders to convince people that you gave a crap about the car and actually maintained it.
Sharon might have changed a tire once. Sharon can put in a quart of oil and windshield washer fluid. Sharon knows how to check a dipstick. Sharon probably just has a good bit of experience dealing with dips.
It's been a while since I've worked on a car. My stupid clutches in my dual clutch auto have gone to hell again. 4th time. I'm so over this car.
We can check and see if the username Minivan1985 is still available for you... just in case.
