The Macgyver thread
Alas, I haven't got a picture.
Still, you know the folding luggage racks they have the a hotel room? Two metal-pipe frames, with nylon webbing straps, unfolds into a sort of a thing you can set your suitcase on?
Set it on end. You will need some magazines to prop it up a little. It's very wobbly otherwise. Now you have 4 legs, the "front", pointed at your model, and the nylon web mesh opposite, on the "back".
Hang a towel over the legs, place a strobe behind it pointing up.
Instant.. softboxish scrimmish thing. It softens the light, anyways. Inefficient as heck, and it leaks lights all over (throw a blanket over it to contain things a bit if you like).
Was at a barbecue the other day and my buddy wanted some quick shots with his bike before he sold it. I only had 1 trigger with but wanted to fire two of my ABs so I figured I could bounce the flash into the slave eye on the back of the other unit. I taped a ruler to the side of the flash, slid a styrofoam plate wrapped in tinfoil down the ruler and it successfully bounced the flash and fired the other :D
I don't know if it's MacGyver-class, but I once rented two strobes and one sync cord was way too short - like 6 inches (yes, really). Attached an optical slave cube to a PC->hotshoe sync cord, rubber banded it under the other strobe, and ta-da, the shoot was saved.
The Zorki S Upgrade by Dirk Desmet, on Flickr
I just upgraded him with a pentaprism glued to a bubble level that is attached on the hot shoe on top of the camera, so I can get my perspectives better and look from above instead of through the viewfinder.
>>>> Very handy when shooting from the ground and you don't want to lay down.
The eye you look at is actually my daughter's, looking from above.
Not really MacGyver... but a handy trick. :)
Not my own idea, someone else did it before, found it on RangeFinderForum a while ago, and want to share this :)
Hey all, I'm new here, saw this thread and thought of something I did last year. Literally minutes before the transit of Venus started this idea popped into my head....eclipse glasses, Al foil and tape on my 70-300mm lens.
IMG_0001 by tgunsher, on Flickr
It worked! Here is the result, you can even see some sunspots:
Venus Transit 4 by tgunsher, on Flickr
