Thank you so much for helping to educate my eyes . I edited photo could you check it out ?Remember with lots of snow your camera is going to make it gray. So set your exposure and then raise you exposure comp up +1 or + 2 that will whiten the snow properly. This results in a much better quality photo than changing the WB in post processing.
I got the idea clearly thank you so much again without good coaches like you it could be harder than ever.Look here is what I could do in a short time about whitening the snow. It is not perfect, it is NOT as good as you can get by simply taking the proper exposure in the first place. DO NOT rely on post processing to correct problems that can be avoided with the camera.
Your response was right on point.
To quote someone I like and respect a reat deal - myself
"The biggest obstacle for most photographers is being objective about their own work to the point where they can stop seeing the picture in their mind and actually see the picture they have taken.
Defining the point of failure allows the photographer to find a fix.
You've recognized that this picture isn't what you want, now you need to dissect that 'failure' to understand why."
Look at each element of the picture and ask yourself, 'Is that really what I saw, how it is?'
That is the key to improvement, knowing how to prevent or correct defects.
