- Thread Starter 🔹
- #16
The barn doors on the Tota's are casting hard shadows, and you have them aimed upward...you can see on the wall the utter mess that those four lights are creating, right?
Try TWO lights, not four. And aim them downward, not upward. You are creating a total mess by using four separate light sources. I have used Lowell's Tota lights before, and HATED them. They are the closest thing to a pinpoint light source ever created during their time. They are AWFUL things unles you have a need for blinding, hot, bright light that will be diffused, and goes all over hell.
You need to diffuse the lights, and remove two of them!!! Two x 750 and two x 500 is wayyyyyyy more light than required. In addition to the polarizing sheets, consider some serious diffusion material, to cut the specularity down. What Tota's give you is a loooooong, wide-profile, intensely specular light source! With four of them, you are just totally,totally asking for problems. Of the thousands and thousands of bumps on the lustre or pearl surface photo paper, you are GOING to get bright, pin-point specular highlights" ie, the white dots, because the lights themselves are very specular when used without heavy diffusion material in front of them.
I've had the lights pointed down and I agree it's too much. I'll try the two 500w lamps and rigging something up to diffuse them. Thanks for the input!
