Using a remote camera during a shoot
socal82
So Cal (Anaheim)
Im doing a fitness shoot and would like to use a remote camera to capture a different angel while I'm shooting. Im using 2 aliens bees 800 as my side lights and a canon flash for main light. I have the canon flash hooked up to a pocket wizard plus x and a pocket wizard on my main camera. The alien bees are being trigger my the main flash. Now when I take a test picture i get a good picture with my main camera but get a black screen with my remote camera. Any ideas? My settings are f8 250shutter and iso 250 on both cameras. It seems like that remote camera isn't going off at the same time as my main camera.
Sorry hopefully i explained it so it makes sense. lol
You don't say how you're triggering the remote camera and if both cameras are identical. When you're dealing with a time span of 1/250th of a second each camera can have a slight difference in it's response to a remote signal.
You could try setting the remote to say 1/60th and close down the f stop a bit.
Is the second camera set up with a remote receiver like the first flash? If so then the second camera will lag behind the strobes as the master flash and slave units are able to respond in less time than the relatively slow mechanical camera operations. By the time the second camera's shutter opens the lights have already doused, and 1/250, f8, ISO 250 would need unusually bright room lighting to expose anything so a completely dark image is unsurprising.
The solution is to cascade the triggers as follows:
Transmitter set to channel 1 on hotshoe of master camera.
Receiver set to channel 1 connected to second camera's cable release socket.
Transmitter set to channel 2 on hotshoe of second camera.
Receiver set to channel 2 on hotshoe of master flash.
Slaves triggered by master flash or also equipped with receivers on channel 2.
It's possible the high shutter speed could still cause a flash sync problem, as the second camera will still expose slightly behind the first. If so then you may see the telltale sign of a bright band and dark band across the image. Normally this means the camera cannot synchronise with flash at that shutter speed, but in this case it would indicate the multiple setup has added a significant delay to the second camera's shutter opening. You could try reducing lag by locking the mirror up on the second camera, but it's less fiddly and more certain to work if you just reduce shutter speed. Ambient light is probably still too dark for a stop or two slower to register, and if not then either use less bright lamps to see your way around or stop down the aperture / lower ISO with higher flash power (if possible). As dennybeall says, you didn't specify the triggering method for the remote camera, or the model(s) of camera used. If this doesn't solve the problem, a follow up with those details might help.
Not sure how exactly you're going about your set up or what equipment you have but if you're looking to trigger both cameras at the same time I'd personally have 2 sets of lets running; one for each camera. It'd be less problematic than trying to get the second camera to sync with the first set of lights, I'm not extremely experienced with this kind of set up in the first place but mostly because I generally would just have a second shooter with their own lights or sometimes piggy backing off of mine (but I hate that).
